Ive got the blue 6.5 clone from HF. Fueling this thing on the DB30 frame is :hang: . Is there any other alternatives that mount a similar looking tank(without the corner folder used for the airbox) in the same position but the cap is offset away from underneath the frame? I would like a tank where the cap is easily accessable in the right side front corner and the tank is maybe like vertically shorter but horizontally longer so cap access is easy and the tank is able to hold as much gas as possible all while fitting the in whereabouts of the stock tank location.
Im going to mod my engine soon(after I exchange it first). So the airbox and stock muffler are probably first to go. So there should be much more space for what Im envisioning.
EDIT: pic jacked from Strigoi and modded for illustration purposes only.
And
I tried to search for what wheels and sizes db30 guys are using but couldnt come up with anything. Is the stock wheel the way to go?
And
