There was just as much play with the valve cover on. I have tested it with the valve cover on. I just didn't shoot the video that way. If I had shot it with the valve cover on people, would not have seen how dramatic the movement was. My mud motor buddies have used the same shims to knock out the vibration in their motors. you never know what is causing something until you test it, isolating one thing at a time.
I'm running the cheap Mikuni clone. I push down on the switch that pulls the enricher up, thus enrichening the mixture. Pulling up on it the lever pushes the enrichener down, closing it off. That's how mine works, not sure about the true Mikunis or other clones of it. I mean I've pulled the plug and can see that it's enrichening when pressed down.
