Going to do a ring job on my Tec
maddcarson
My engine needs a piston ring job bad. the bore is full of nasty stuff and the engine just wont run rite. When i have it full throttle it keeps slowly dying out and im going through spark plugs like crazy. So before is start i would like to hear if you guys have any easy wasy to change the rings or just imput on the engine.
mybiz
New Member
I haven't rebuilt a tec motor lately but $80 should be more the enough money for a major overhaul as long as your piston and valves and crankshaft is all good. Here is an example.
HS50
Includes - gasket set, oil seal set, valves, piston and rings.
SizeItem #Your PriceBUY NOWStandardRBLD84$68.95
& ONLY $6.95 SHIPPING
Quantity:Add To Cart
.010RBLD129$73.95
If your cylinder is worn badly take it to a machine shop that does small engines and see if you will need to bore .10 over or .20 over before buying parts and needing the next step up in a rebuild kit.
