picked it up out of the trash the carb is locked up and the bowl is coated with silicone, theres no tags on the engine. sprayed some starting fluid in the carb plugged in the elictric start and it fired rite up. the engine has an 3/4 shaft tapped and was chain drive with a clutch.
no number on the shroud theirs 2 holes on the side where i guess a tag used to reside long ago. i was at sears website with the part mumber and it said 756190 was the replacemen engine number for this model blower and that mtd made it for sears.
