Hey guys, I had a question about my predator. I searched and couldn't find the answer for my set up.
My set up
-212 non-hemi predator
-nr racing ported 18cc Honda head milled .050
-cm push rods stock length
-reinforced rocker arms stock ratio
-.016 copper head gasket
-lash caps
-black mamba can
-arc rod and flywheel
-head and side cover studs
-22mm mikuni
-Robertson torque loop header
The ported gx200 head didn't come with guide plates, I was wanting to know if I could use my predator guide plate and rocker arm studs? Also do I adjust both valves at the same time at TDC? Thanks for any information or tips. I'm new to the clones, this motor is going on my small Jon boat that has a stock predator on it now.
My set up
-lash caps
-black mamba can
-22mm mikuni
