Get the ARC rod made for the Predator crank, and the flywheel...
Are you using the Gx200 piston? Or do you have the gx200 bored to accept the Predator piston?
In mine I used the predator crank, .020 predator rod, and a UT2 gx200 piston...( has a shorter comp. height)
Brought me upto .010 in the hole used a .018 gasket...
Originally my gx200 was .045 in the hole...
This is what we call the mini stroker... Run nice, picks up rpms quick, lots of torque...
This is with a 14cc head, 27/25 valves, head P&P, and a Black Mamba cam with a 390 carb. on meth.
Had to brace the block quite a bit to keep it from blowing the jug off..
