To all those who have the 6.5 engine upgrade (more specfically the HF engine as i'm not sure if other brands are the same), how did you hook up the throttle cable. I was gonna make a small L bracket for the main cable to feed through and hold it in place but its the end of the cable itself which has me scratching my head. I have the little bolt/screw with the hole in it which cinches it down. I was going to attach it to the throtle arm itself in one ofthe provided holes but theres absolutely 0 room beneath it to attach the c-clip which holds it in place. If I even try I'm afraid it'll pop off and fall deep within the engine. Any tricks to making this easier. I'm stuck.
