Alright, so I need some help. I'm hooking up a Honda GC160 on my bike, it ran perfectly before I hooked it up. The only "mods" are the header, air filter kit, and crankcase breather. I'm trying to hook up a different tank to eliminate the stock side tank and the fuel pump setup. However, when I fill the tank with gas, gas fills up the bowl and comes dripping out of the air filter in a nice steady stream. At first I thought randomly maybe I damaged the float needle, took the carb apart and the float needle is fine. Why is it doing this and what do I need to do to fix it? Do I need to install a valve coming off the tank? The motor fires up fine when I pull the tank and let it run off the gas in the carb bowl, but whenever the tank is hooked back up gas just comes pouring out of the air filter. Thanks for the help, and here's a couple pics to let you know what I'm trying to work with.
