I'm converting a Honda GC160 engine from constant speed to "hand throttle"
I'm using the Honda part 16500-ZL0800 plate.
I think I have it on the engine correctly. If I do,the hand lever would need a rod to go across the engine to the governor / carburetor throttle lever.( the really long lever attached to the bottom of the engine)
How did you guys hook up the hand lever to the engine?
Also,did you use the new kill switch or keep the rotating kill switch?
What did you use for a twist throttle hook up?
Photos would really help.
Thank you.
Thank you.
