Well my late winter project is finished .I basically built this engine around the cam ISKY 350 lift 246 duration welded cam . I started off with a honda gx200 block and crank align bored 20 over balanced the crank rod and piston assy. I used a 18cc gx160 head milled .050 28.5 intake 25 mm exhaust Nuen cnc contour valve job ported intake and exhaust installed new guides as well, heavy duty valvespring kit chromemoly 1/4 " push rods champion rockers Isky billet lifters . Actually 90% of the parts came from Tim at Small Engine Cams real great guy to deal with and has all the parts to get you a great build . The piston is a .020 honda flat top piston with an HD wrist pin , ARC stock length billet rod along with a Raceseng S2 non finned billet flywheel and a AGK 2 stage header . The carb is a HL304 Tilly with a little work in it . Im using a Honda G160 head gasket with grade 10.9 bolts with hardend washers . I should end up with around 10.25 to 1 compression if my math was right . I just cant wait to throw it on a frame and fire it up !
