How to Install a TAV on a 2005 Mini Baja
I have a Mini Baja MB165 that I would like to put a TAV torque converter on. What ( if any ) modifications will need to be done? Where is the best place to buy the TAV at? Heres a picture of the bike.
Thanks
It looks like they have two kinds for 3/4 shaft; 12T and 10T , which kind would be best?
Thanks
9 tooth with a 420 chain.
That means buy the one for 41 chain, use a 420 chain ( you will need to buy some chain ) and then buy a 9 tooth C type sprocket to replace the 10 you have.
OR you could just run the 10 but that makes for some miss match in the gearing some people find objectionable.
5/8" Bore C Type Sprocket 40/41 chain
