ok here is how to get the flywheel nut or sprag clutch off a brigs and stratton with simple hand tools .
ok here we got a block we need the wheel off but cant get it to stop spinning .
well remove the spark plug
feed in some small rope here im using about 3/16 dia rope about 2 feet
keep feeding it in till you have a little tail sticking out to pull it back out
and now we have a motor that wont turn over
note do not use big pipe wrench on motor . just using it to show its locked up now
and here is what it looks like on the inside of the motor . note the rope is in the cylinder on top of the piston . you can also see the ports where the valves should be on the left side of the block
ok now for the sprag clutch . take a punch and line up to the big tabs on the clutch . hit the punch with a hammer and walk it around till you can turn it off by hand going counter clockwise . note plastic or wood is better to use then steel less chance of breaking the housing . but i have done it like this for years and only had like 3 break on me . your choice use what ya got .
what was that . i heard that ya you , talking about i have the newer basket type starter . well i did not forget about you here is how to deal with them too .
ok so we have the basket on there and the nut in the middle well we will need a socket and ratchet to fit on the nut
now you can ether pull real hard or its hammer time cant touch this my my music makes me so har...... oh what wrong hammer:doah:
ya this one will work better .and with a smack we have it loose
and with the starter removed we have a washer . remember how it goes , it will mess with you if you dont put the correct side in .
ok now we need to put some pressure on the flywheel . pry bar works nice here . you dont need to go wild on the bar just some push. too much and youll bust the case . or crush your points if you have a older motor . so look where you put your prying tool .
