A while back I ordered a custom ground .265" modified cam from AGK and I installed it without really paying attention to the box. I just found the box and it says "Dyno Cams 275 clone" on it. It also has a yellow piece of paper in it that says:
Grind Number:275 clone
Recommended Class: Mild Modified Clone
Valve Timing:
Intake Exhaust
Open:42 BTDC 77 BBDC
Close:78 ABDC 36 ATDC
Lift:.275" .275"
C/L:108 ATDC 110 BTDC
Valve Lash: .006 .006
How do I know if they sent me the correct cam in the wrong box?
Anyway, I was looking to see what the valve lash is supposed to be and from what i have been told it is normally .002 and .003. But the paper says .006 for both? Which one do I need to set it to?
I just installed 26# spring on my new 14cc head and I need to know if I need to run 18#? If so, I will have to order some :doah:
Thanks in advance!
Valve Timing:
Intake Exhaust
Lift:.275" .275"
Thanks in advance!
