I picked up a Super Bronc that someone did a mild resto on. First off they painted the engine and it looks like the ID plate is gone from the Fan cover. Is there any casting numbers or something to help me ID this engine? I was told it is an 8hp. I pulled off the flywheel it had a part number of 13-0-39, the points cover is P/N 610883 If that helps narrow it down. The Carb is also located on the PTO side.
I'm also having an issue with it running. Once its warmed up for 8-10 minutes it dies and will not increase in rpm with throttle. I was first thinking it may be a gas cap issue but that's not it (tried a known good cap). So I'm thinking the ignition is getting heat soaked or ??
