"This Minibike has large tires that make it good for loose sand. The front tire is an airplane tire",.... slick as snot, guaranteed to bust your a$$ with the first turn you attempt
How about the fact there is no way in hell you can contact the ucking idiot. It gets reposted every 2 days the same way. Guy needs to get a freaking clue.
Drop the rear tire down to 5 PSI and it would be a good sand bike. We used to put WWII surplus B-25 aircraft tires on our Jeeps and run the dunes in Charleston,SC and they worked real well. It low PSI they stuck to a dry road very well.
450 is not too bad of a price and the front end could be re-done.
bull dukey. works for 4 but not for 1. I live in the sand, you need deep tread or the front end will wash out, and a face plant will happen. ptoo been there
yeah it could be different sand too I was thinking. It is pretty loose and deep in spots around here, so you need tread to grip when you turn. big difference between street tread on the front and a knobby.
not stealing you thunder you big monkey, I'll get back on topic I swear: Check it out Rob, pretty cool Eh? about 150 miles away. Two wheelers have tread on the front tire, 4 wheelers usually don't:
