Starting a ground up project with a custom frame for my son. I plan to use a predator engine with a tav. Assuming I will need to use a jack shaft, I will also be building a rear swing arm. What size sprocket should I put on the jackshaft to keep the ratio 1:1 with the driven clutch pulley from the tav?
