Has anybody really thought out the pros and cons of low rpm torque monster vice a high rpm screamer? How you set up any engine is a function of torque and horsepower curves, and the ultimate use of that engine. A big block Chevy truck may produce power in the low end of the curve and tow 10K pounds, but is no dragster. A Ferrari may have more total horspower, but it's available higher in the curve, and you wouldn't tow a camper with it.
I can understand if I was into drag or kart racing, I would want to squeeze every last rpm out of the engine. Seems to me if I want to focus on riding in the dirt, I'm more concerned about low end grunt; getting the torque and HP peaks in the low to mid range. I'm thinking the following would work well.
Arc rod
Flat top piston
Mildly ported 14cc or shaved 18cc head
low-midrange cam (recommendations?)
18lb springs
Bored carb or different carb
Header
High flow intake
advance timing
With this setup I could leave the governor and stock flywheel in place and add a TAV, and maybe tweak the final gear ratio. I think this would give me great acceleration and a top end around 45-50 or so depending on the gearing. Right now my nearly stock Serengeti Puma with a TAV will do around 37mph. Thoughts? Comments? Suggestions? Am I missing something? Do I have my head up my butt?
Arc rod
Flat top piston
18lb springs
Header
High flow intake
advance timing
