Newbie - here with a question on isntalling a Max Tor clutch which I could not answer by using the search button. When installing a Max TTor clutch on the 6.5 HF engine are shim washers used on the crank side ? Pro Mod send 2 shim washers but they don't take up all the clearence on that side ? Do you lock dn the set screws ? and lastly if no set screws are used is it then just allowed to float back and forth.
I watched a video (for go carts) by Max Tor - Jim Donvan Sr and he states to let the clytch float back and forth and just the bolt/lockwasher and washer are needed threaded to the end of the crank shaft. Confused and app any help/guidenance.
Thanks
Thanks
