You have idle air screw on the bottom of the carburetor. I set mine maybe two turns out. It doesn't do much I think.
Then you have Philips head mechanical setting screw on the side. That is to adjust how high or low the slide sits. (Mechanical idle) Screw out to lower idle.
If you have adjusted those, maybe your throttle cable tension is too tight, and keeping the slide up too high.
