Hi everyone, just starting a new project and figured I would start a thread on it.
I acquired a brand new, complete Azusa 8" wheel mini bike kit on craigslist for a steal. It also came with a new 6.5hp Dupor clone engine and a Comet torque converter. The engine has some performance parts with it also; a cam, valve springs, big carb, etc. I guess I will install the performance parts??? I know almost nothing about modding clone engines.
The plan is to build a 2x2 mini bike as if Azusa were selling a complete 2x2 kit. My last 2x2 definately looks homemade. I want this one to look stock and professional. I still need to order a couple 5/8" jack shaft kits and a few other things from OldMiniBikes, but I have the two hard to find parts already...... the steering u-joint and overrunning coupler. I am using much smaller/lighter parts on this one. I found a tiny 5/8" bore u-joint that still uses needle bearings, and I'm using a Proto brand 1/2" drive ratchet adapter as an overruning coupler. I plan on grinding one side of the ratchet mechanism off, so with the twist of a collar on the rear jackshaft I can switch between one and two wheel drive. (Key in pic for size reference)
I'm using 480x400-8 Oregon tiller tires and a rectangular fuel tank from an old Kohler Generator. I can't decide if I should run a front drum brake just like the rear or if it would be unneccesary?
