Time for an adventure in engine building. I am putting a .563 stroker crank in a BRIGGS block. This engine will end up being the equivalent of a blockzilla in briggs clothing. So heres my parts list so far:
Briggs Bearing block .10 over, lifter area welded, HEAVILY clearanced
Pure Power .563 (7/8 journal) stroker crank
Dyno 126 cam
ARC 4.225 or 4.275 rod
Wiseco 1991 piston
Alky Tillotson Carb
Dyno Green Stripe Springs
Big Valves
3hp Flywheel
I will post updates periodically as I am working on this project. I am still undecided on a few parts of this project like header, length of lifters, size of valves, spark plug, and a few other small things. Any and all input is appreciated. Let the fun (and grinding) begin! :grind:
Dyno 126 cam
Wiseco 1991 piston
Alky Tillotson Carb
Big Valves
3hp Flywheel
