Mounting a Mini on a wall
nightgrider
Assuming a full bike, frame, tires, and engine. Probably have to make a custom shelf that is capable of 200-300 lbs. (just to be safe). Mounted to the wall studs and a safety cable would be good to keep the bike from coming off the shelf by accident. Could cut a good amount of weight with a fake engine. Not sure if they have Styrofoam or plastic mock up small engines, like they do for V8's. Though gutting (no crank, rod, piston, cam, or valvetrain) an old engine would drop a good amount of weight. If it just for display.
pomfish
They never look as good on the ceiling unless it is like a Go Kart frame only mounted upside down pan Flush and even then you have to be back too far to appreciate it, Wall gives contrast.
P.S. Skipp,
Love that light green engine. What is it from and what size/year?
P.S. Skipp,
That’s a special motor…68 hs40…very light use…going on That 67 bonanza hanging there…
