It does look a lot like a Bozo,but the rear dropouts are different-the Bozo's are similar to a Lil' Indian or a Manco. The ones on this one are outside of the frame,making the wheelbase a few inches longer. Also,the engine plate suggests that it was not powered by a typical 4 cycle lawnmower type engine. The scrub brake lever was obviously two pieces welded together. The rear sprocket is 82 (yes,82) teeth !!!! I think a Lil' Indian or Ruttman sprocket will fit-it has a 4 bolt pattern. Some of the welds need cleaned up and some additional welding and gusseting is necessary before I put my 225 lb. 5'10" body on it........One thing's for sure-it will be one of a kind !!! More pictures are forthcoming. Thanks for your replies.
