I have a briggs 250cc 1150 series that came off a tiller on my bike. It was the weird motor in between the 206cc with the 3/4 shaft and the 305cc with the 1 inch and its rated at 11.5 ft lbs stock and also has a 3/4 inch shaft , since ive had it ive opened it up by adding a mikuni carb and a straight pipe to it which helped a lot ( i'm thinking 9 or 10 hp and 12 or 13ft lbs. I am running a gear ratio of 12/40 on my bike with a 5 inch wide 12" slick on the back. I know my engine should be capable of reaching at least 3/4s of the top speed of this gearing, but i think my clutch won't let me. I can't get past 34 mph and i can feel power in the engine, but it won't transfer to the rear wheels after that. ITs not even topping out in RPMs. Should I buy a racing clutch? I am using one of the cheap $35 max torque clutches, but i know they are rated only from 4-7 hp? Help?
