Hello I'm rebuilding a minibike I got when I was 10.I'm now 14 and my original motor (49cc) on it broke so I just switched it to a Honda gc160 I got with my go kart.I want to make it go at least 65mph but I don't know how many teeth my clutch should have my jack shaft in has 21 out is 21 and sprocket is 44. Tk
Hi Rocket, How tall is your rear tire?
If you have an overall height of 12 inches on your rear, and use the widely available 12 tooth clutch, you would need to swap out the input jack shaft sprocket from 21 teeth to 11 teeth. (Or do a combination on both jack shaft sprockets) That would give you a theoretical 66 MPH at stock governed RPM of 3600.
Your engine probably doesn't have the torque to maintain power at such a high gear ratio however. Those MPH computations are theoretical and don't address torque.
I recommend you first get that 12t clutch, and get the replacement engine and bike working well together first. Maybe do a bit of wrenching and learning (as we all have done) and maybe plan for a larger engine, or faster setup in the future.
By the way, if you have a 12" rear tire height and go with that 12t clutch, your top speed should be around 35 MPH, which on a mini bike feels pretty fast to me, especially with 12" tires. Also, it doesn't hurt as much as it does at 65 when you crash. :thumbsup:
