new parts = no start
Removed governor
18lb. Springs
Air Filter
Exhaust 1"
Timing key 6 degree
Emulsion tube 140 + 37 jet
No start choked/non-choked.... Occasional blue flame out exhaust n carb..
Swapped back stock emulsion & jet got more blue flames out of carb n exhaust..
I may have failed on setting lash because I don't know if I was on compression stroke. I'll recheck that. I don't know if timing key should go back to stock as well.
All other suggestions welcome !!
Ok seems valve lash was culprit. Way to tight and wasn't allowing valves closed. Backed it off to stock IN: .006 EX: .008
Fired right up. Next thing is to figure out lean / richness
Man this thing runs great .. Can't wait till I dial in proper jet combo .. Still learning about cold vs. Hot and what choke does during each etc..
