Weed whacking a Drive Sprocket and reckoning a Front Fender
My OldMiniBikes order came on Wednesday, and today I was able to play a little bit. I could have bought a universal drive sprocket, but I just don't like the look and besides, it's the easy way out. The original sprocket (36 tooth) has a 1.47" pilot hole and the new (60 tooth) has a 1.375" pilot hole. The final drive ratio will end up being 6.33:1, giving me a little better bottom end with the HS50 that is going on the bike.
To center the new sprocket to the original sprocket, I got creative. I had a 1.375" dia diamond hole saw that fit the pilot hole of the new sprocket perfectly--nice and snug. Then the old sprocket was placed over the new...there obviously was a gap that needed to be evenly filled to center the bolt pattern. To fill the gap, I used two pieces of .080" weed eater line. This was a good choice because the trimmer line has just a little compressibility. I fit one length in to cover half of the perimeter of the pilot hole, and then the other half of the perimeter. Perfectly centered. I then used a 3/8" bit to locate the centers of the bolt pattern, drilled pilots and then drilled the 3/8" bolt holes. Exactly right and double checked with the brake drum.
The front fender is going to be interesting. I had looked to see what Unorthodox had done with his front fender, so I ordered a fender from OldMiniBikes. I really don't like how the rear of the fender flares out on the front wheel on the original bike. Since I can't be completely original, I'm going to replicate the original shape of the fender but allow it to wrap a little tighter to the tire. I'm also going to move the mounting holes on the fender back a little further. I wish i could do the same with the rear, but ain't happening.
