I'm in the process of finishing up a 78 MT1.
Bought it disassemble (partly my fault while draining a few beers in the garage), from a buddy of mine with a bunch of new parts; cables, emblems, handles, tires, chains & sprockets. Came with papers, Yeah! Had the frame sandblasted repainted & cleared. Motor is untouched for now as it was running, so hopefully it will for be a while.
Here's where I'm at so far.
I tinkered with the old throttle cable today. Manage to get the carb and oil pump working at the same time. There is no adjustment on the oil pump cable. Seem like it was replaced, from the splitter, with a length of bicycle cable at some point. So to hell with it. Thing is, the new cable has the wrong carburetor end, so I'll have to keep that part. If it was done before I guess it's not that big of a deal to do it again.
For the front brake, we have apparently the wright parts number cable. But in order to have a brake lever feel that make sense, we had to use the old spring (not butchering the new one) and cut it down to around 1.5''.
Is it possible that the arm on the dust cover and the lug inside (that force the brake pads out) shifted position relative to each other? The arm on mine is probably at the 1:30 o'clock position. See first picture how adjustment is out. It looks all crimped together? Plenty of meat left in the pads. I tried clocking it 180 deg, nope. Edit: thinking about it now, might be some brazing at the edge on the inside lug... Have to open it up again.
