I picked up an old Rupp to restore.
I have it painted and am putting it together. I put the swing arm back on the frame the same way I took it off, but it doesn't make good sense to me.
It attaches with 2 bolts and lock washers into threaded inserts in the frame, and that's it...
If I tighten the bolts down the swing arm locks up. If I leave them loose I'm sure they will work their way out.
Is this how these minibikes are done? If so I think I will cross drill the frame and bolts and use a cotter pin and replace the lock washer with a flat washer.
Thoughts?
Thoughts?
