Well heres my current project which will be done with a few more modifications.
I bought the frame off of a friend for $50. all it had was the steering assembly.
I had planned on using a gx390, so the engine plate had to be moved up a level, and right about 7" to fit space for the clutch/sprocket/disc brakes.
Then after everything was repaired, freed up, replaced the front bent frame piece, base coat of black, etc etc...
Rode it around for a bit and it was WAY loud with this pipe.. I put a baffled propane can on the end and now it sounds much softer, with the same amount of power as before.
I needed new front tires because the stock harbor freight ones are pure garbage.. they bend and dont grip at all..
And now the paintjob. :smile::smile::smile::smile:
Ill be removing the seat and replacing it with a cushioned toro mower seat to hopefully dampen the vibrations. I had to also mount extra pipe to the direct bottom center of the engine plate to keep it from shaking so much.
