Yes thats what i did . I have the champion rockers and needed the tall cover , well Tim was out of stock when i got my cam and rockers . So instead of waiting for them to come in or buying the costly spacer , i went with plan B . Which is pull out the guts of the cover then you have enough room for the rockers , but still need the valving that was removed . Bought a 1.99 pcv valve the smallest i could find , couldn't put in the stock hole cause it will hit the rocker . So drilled a hole on the front top center and it fits right between the rockers .
