A basic Joe's medium size frame. Then we added some mods. We started with cutting off all the original frame tabs, motor mount plate, and neck. We then widened the frame to 13" and installed a go kart motor mount and shortened the height of the frame by 1-3/4". After that we raked the front end to 63 deg and installed a bearing supported neck. Next we installed the live axle setup with mechanical disk brakes and a rear sprocket hub with 35 chain. We then moved to the front and made new drag bars. As for tires, the rear tire setup is a 6" rim setup and 8" wide and 12" tall. The front is a Azusa spinner also 8" with a pocket bike front tire. Next is to install the head brace and the rear frame supports. Before anybody comments about the rear support bar, it is getting moved up. It was placed there to keep everything straight during the widening process.
