so i dropped a valve on my pred motor and i decided to put the raptor 3 motor on my spyder...
BIG DIFFRENCE!
the bike pulls like a raped ape
the mods to the motor are...
big cam ( not sure on size)
arc rod
bigger valves
eyebrows shaved
decked block and milled head
double valve springs and aluminum retainers that are a BIT*H to remove fyi
3 hp flywheel
tilliotson car intake and stack
3 stage trumpet end header
bullet lifters
welder lifter area
.10 over flattop piston
portedand polished intake port and exhaust port
the intake is matched to the block
the bike currently did 54 mph with me on it 320 lbs.
with issues i dono if its low on compression or its the carb
need to throw a comp tester on it and find out.
motor makes anywhere from 15-20 hp according to my EX autoteacher who built it the thing halls ass and i had it past 7500 r.p.m on my other frame a couple years back heres a pic
BIG DIFFRENCE!
arc rod
bigger valves
eyebrows shaved
3 hp flywheel
bullet lifters
welder lifter area
