I'd use a hydraulic press but a big hammer would work. Put a piece of solid aluminum on the sprocket and hit that instead of directly hitting the sprocket---saves putting hammer marks in the sprocket. Since metal springs back when bent you might need to put a thin metal shim under the bent edge so the hammer blows will initially bend it a little farther than necessary.
