While preparing my "forty" Fox Campus wheel rims for painting I ran into a problem in that they did not want to hang vertical. See Pic #1. After testing and scrapping twenty or more methods I came up with a bracket that neatly solved the problem. Pic #2 shows a hanger that I fabricated out of 1/2" X 1/8" flat iron. After bending the hanger to shape; a 1/4" bolt was cut to length; notched on the end; and tack welded into place like in Pic #3. Pic #4 shows the rim now being held vertically with plenty of space for spraying and only touching in two tiny areas which will not be visible once the two halves are bolted together. Pic #5 shows the front face of the rim which is now totally open and free of any obstructions. In less than two hours I whipped up twenty of these hangers and that will allow me to spray twenty rim halves at a time. Ogy
