Hello Folks,
The rear wheel on my Sensation Mike Bike is a Rupp turbine wheel that was on there when i bought it :shrug: .
The bearing on the left hand (sprocket) side of this wheel has disentigrated.
(Am figuring from my research the failure is due to the fact the rear wheel was spaced with big washers instead of proper diameter spacers.)
When the bearing went , the lip of the wheel hub got dogged up some..so it does not look like a smooth enough surface to install another bearing (see pics of good side that still has bearing:
and bad side w/ dogged up lip and no bearing (click photo and enlarge to see detail):
My question (in the interest of cost effectiviness :wink: ) - is it theroretically possible to 'repair' the hub. For instance, can the bad side of the wheel needing the bearing be machined to provide a smooth interior and lip surface again, and then a new bearing installed ?
Or given this scenario, is the hub trashed ?
Thank you,
Robert
Thank you,
Robert
