Sensation chopper build, I'm need help in figuring out what size clutch and rear sprocket to use? Here's the details,
1) Tires are 4.00-5 and are about 12"tall
2) Engine I'm using is a Tecumseh HS50 (5hp) 3/4' shaft
3) Rear Sprocket is a 66 tooth size 35 but is worn out
4) and I'm pushing about 180 lbs
when I look up clutches, they list 11, 12, tooth etc and diff launch rpms, and what ratio would work best to move me, at 55 I'm not much of a speed freak , just need to pull the hills at the Carlisle swap meets. any help would be much appreciated, thanks, Billy
