So I bought a 2002 murray track 2 for $150, the throttle has a connecting wire missing, there is no brake at all, chain is loose, starts to die a couple seconds after starting. I am working on fixing all that, and will be swapping engine with a 212cc preador in a couple months.
My question is I want to turn it into a speed demon, I am unsure how to remove the governor, and I want to change the sprockets because of rust and clutch does not sound right so I’m going to mabye change that. I don’t know what sprocket size is good for speed, and I don’t know how much rpm the sprockets will cause because the engine is old and I don’t want to go over 4700 rpm.
