Hi - I'm trying to figure out what parts to buy in order to set up a new rear end on my minibike. I see various wheels and hubs, but what's confusing me is, how do I center the wheel on the axle and space the sprocket out so it's aligned with the clutch? Some hubs I see are two inches, some two and 3/4, but I need a little more than that to put the chain in the right place with the wheel centered in the frame. How is that done? Also, I'm thinking that I can buy a two piece wheel, and put a drive hub on each side. I think somewhere I saw a brake mount, maybe that's what I need for the brake side instead of a second hub. The left side would hold the sprocket, the right would hold a brake disc or drum. Does that sound workable? On the brake side, I can mount a caliper anywhere, because I'll weld mounting brakets to the frame, but I'm still not sure how to space the sprocket out. Can I use spacers on the bolts (and longer bolts) which mount the sprocket to the hub? Is it that easy? Thanks!
