I am looking to put a stage 2 kit on my predator motor. I have a header already. Purchasing a Billet flywheel next time I'm at motor city minis. What stage 2 kit would you guys suggest? There are so many carb options available and don't know witch way to go. I do not plan on going past the stage 2 kit on this motor. any imput would be awesome.
I too am not real sure what you mean by stage 2, different stores sell different kits and call it a "stage 2".
These "kits" usually include stuff you don't need and won't use. I'd make up my own version of stage 1 and stage 2.
If I were defining these stages I'd call "stage 1" just basic breathing, something like:
1) a high flow air filter w/adaptor,
2) a carb re-jet kit (main, pilot and e-tube)
3) an exhaust header
for a kart I would include:
4) a fuel pump w/ pulse fitting (which doesn't do a mini bike any good but
it's needed for a kart that has a gas tank lower than the carb where gravity won't flow gas).
5) and a top plate, to mount the pump and linkage for a kart, after the tank is removed.
Stage 2 would include stage 1, plus a little more muscle in the engine:
1) advise on a) removing the governor, b) selecting a billet flywheel and connecting rod
2) a cam, your choice of CL-1 improved, or MOD 2 (CL-1 will pass inspection if you're racing, Mod 2 will not)
3) 18lb or 26lb valve springs, w/intake valve cap
4) flywheel offset timing key (your choice 4,6,8 degree)
5) Autolite 3910 spark plug
So there's a few idea's you can work with,
as
Newoldstock said:
"You mix and you match...You rework the engine...Soon you learn what works and what does not".
Add a flattop piston, high compression head, stainless steel valves, chrome-moly pushrods, ratio rockers, etc...
pretty soon you'll realize this is getting into some real money and then eventually....your wife will find out about it
:hang:
