Hi,
I have a stock Baja Racer 97cc that will not idle with the choke off. It idles fine with the choke on, but of course will not throttle up. It does not idle even with half choke. It will run well if I hold the throttle on and turn the choke off, but the second I let go of the throttle, it dies. I have been through the cab. many times and cleaned the main jet as well as the idle jet below the idle adjustment screw. I have also tried adjusting the idle/ air mixture screw after prying the black limiter cap off with no results. I am stupmed at this point after cleaning the carb. many times and adjusting as well as trying fresh gas and a new spark plug (NGK BPMR6A). It also does not matter how long I let the engine idle on choke, the second I turn the choke off, it dies.
Please help.
Thank you
Please help.
Thank you
