Put simply a TAV setup uses the belt drive which as it slides down into the rear pulley changes the gear ratio. Each time the belt thickness slides down the thickness of the belt you get a different ratio, usually about 16 different ratios. That gives you a 16 speed automatic. Power to pull a hill, and the speed to run on flat ground.
