Well, that only took a year and a half..
The jackshaft plate I had made got bent, so I figured this would be a good time to mess around with a cheap TAV.
I guess we'll see how this holds up, I have the sprocket on the outboard side of the driven pulley. I was able to use the original shaft, with three washers behind the driven to space it out and by grinding just a little off of the backplate fins. Oh, and by using a 5/8" thin locknut..
The driver is spaced away from the engine (a Tecumseh I got cheap) with two washers. I went with the Tecumseh because it fits the Tav like it was meant to be..
Which saved me modifying the frame or lifting the engine up, although I had to move the engine to the right about half an inch. I could have moved the sprocket over, but the chain would hit the tire. Still might have to fine tune the alignment.
I'm waiting for the carb to arrive, then I'll be able to try it out.
Too bad about photobucket, but there are pics of the bike in my 'rides'
