So I am test fitting everything, installed drive and driven nice to realize the rear sprocket and jackshaft sprocket don't line up.
Now if I space out the jackshaft sprocket to match the rear wheel sprocket,then the driven pulley moves forward, then the drive pulley has to move forward which doesn't leave space on the crank for the collar to go on.
Motor is gx200 clone.
Can you space the rear sprocket off the wheel flange with spacers?
Also what's the best way to perfectly align the 2 sprockets together? I will try a straight edge that's thin to get in there but not sure if that's 100% accurate.
