3 HP TECH engine,has a out put shaft of 15/16 " size need a clutch.as close
as i can find is 3/4" inebody ever had to deal with this,eny ideas?? thanks.
We had this problem with a Harbor freight clone motor the crank was just a little big for a standard clutch so we took emery cloth and a flat piece of metal on top of the emery cloth and held it down on the crank while the engine was running and moved it back and forth until the clutch fit. Or you could use a bastard big file to cut it down quickly and run it back and forth and then fine tune with emery cloth.
