i think i found the bore size 2 1/2 sound right? same as a 4hp but has a shorter stoke 1 27/32 = 1.843+
if your mains are the same as a 4hp crank? you could stuff a points 4hp crank and the factory 4hp aluminum flywheel.
now you can use a billet rod all day. the other problems you might have. thats if the first part works and fits correct?
if the steel sleeve will let you bore out to a 2.625 bore? or at that point remove the steel sleeve(because its to small to bore out)and you still have enough room to stuff a 2.625 piston?
your engine would go from a 9.06 cu to over 10 cu
now if you have past all thoses problems?
you could install a stiffer spring. i believe a briggs animal #15+ with some aftermarket retainers and locks. then you won't get any valve floating with the stock cam and the springs won't be to stiff and eat up the cam. i would think at that point you could get that engine to spin 4500+ all day.
now if all that did work...big if? you could get a after market cam . for example a dyno 245 cam. now you would have to reverse the intake and the exhaust set up and install a larger valve that use to be the exhaust side and is now your intake( i can see you hanging a small 20 or 22 mikuni on it:laugh:....all day), remember the 4hp and 5hp has the factory exhaust on the right,so the cams are different then yours.
you could have alot of fun with that little flathead motor if you could get that crank and piston size to fit. also if your block has enough material like a hs 5hp motor does? you could bore it out to a 2.805 now your cu.in. is getting real BIG
just think what kind of power you would have with that little side popper.....:thumbsup: you would be the coolest flathead kid
on the block and the fastest..........
