I know this topic has been covered before and I have read other posts, but what I have not been able to find either in the manual or online is if there is a initial position to install the magneto ? the reason I ask is I installed the mag with the bolts that hold it down in the middle of there mounting slots, then I installed my dial indicator (head is off) next I installed the points, turned the motor to TDC compression stroke which put the lobe on the crank at the highest part, set the gap to 0.020 then rotated the crank back to 0.035 BTDC and using my self powered test light I rotated the mag until the light went out, tightened the mag and rotated the crank fore and aft watching the light go on and off at 0.035 BTDC The problem is when I put the flywheel back on the magnets hit the mag, I have tried several different times but the mag always seems to be cocked and the magnets hit the mag in other words the bolts are not in the same spot on both slots, so I guess what I am really asking is if there is a specific way to install the mag ? and what the heck am I missing here ?
