Can anyone tell me anything about this engine from this photo ? I am old it is a 10hp but I haven't checked the engine numbers. I know nothing about small engines, would this be usable on a mini bike ?
Looks to have shaft tapped (bolt and thread) and a straight shaft (not tappered) so would be good.
Need to know if it's 3/4 " or 1" shaft??
1" is harder a little hard to work out the driver.
Needs to go on big tire/frame bike, not the little stuff!
Steve, that engine would work just fine on that mini bike.The clutches that fit 1" crankshafts are a little pricey but they are readily available. where are you located in IL?
[/QUOTE]EDIT: also it looks like it's been sitting out side, you might check for water in the oil just in case.[/QUOTE]
Yes, I'm not too sure about it's condition.
