From what I have been able to find out,the way to check a Tecumseh carb is to shake it and listen for the rattle noise.You do this with the float removed,and holding the throttle and choke levers.The check valve is a small metal rod or emulsion tube.Any way the vinegar did work a little to clean up the powdery oxidation.I also soaked the carb in carb cleaner and used an old tooth brush.I'm waiting for some new floats to come the old ones have pin holes in them and one was full of gas.I still haven't tried to remove the Welsh plug in the side of the carb,there is supposed to be 3 holes under there that can be cleaned out.One trick that I have used is to rev the engine and close the choke and open the throttle wide open to suck out the passages in the carb.This works on older cars too.
