I recently picked up what I think is a model 530 Tote Gote and have started the process of making it a rider again. Started out with the basics; clean out the tank, fuel line, new tubes, oil, etc.. It still had the original Dayco 2-D belt on it and was on its last leg. There isn't much information out there on these machines so I called a local belt, chain, and bearing place for help on getting a new belt. With a rough estimate of 42.25" in diameter and 7/8" wide, we decided that a 1422V420 belt should do the trick. Put the new belt on and fired it up for its maiden voyage down the driveway and back. I was expecting it to take off like my fathers Bearcat Twister but it seemed to go much, much slower.
From what I can see when riding it, the forward clutch is doing its thing and contracting onto the belt and making it ride up. Its only making it about half way up though. The same thing on the secondary clutch in back. Its not pulling its self down into the clutch. I can open up the secondary clutch by hand and the spring returns it to the closed position. My only guess is that the belt is too long. The engine is already all the way forward on the plate. What size belt should I go with next or is there something else that I should check in the drive system? Its only going about 4 miles an hour. This is my first time working with a converter setup. My other bikes have always used centrifugal clutches.
I'm also in need of an oil bath air cleaner and a original rear fender and bracket if anyone has one laying around!
